I agree with what they are saying .. I had a old LS6 -454 and it would push my V-Drive 82-85 MPH all day long and never had to work on it .I could run 28 miles to the dam and back in Granbury without having to worry about anything . It ran 8 years like that .. Then I got this dumb ideal that I wanted to go faster .. Bought a 509 high compression engine and jumped to 102-104 mph and ever since it is more of a play boat than a lake boat .. Constantly working on it or breaking something .. Build a solid 500 Horsepower BBC and go have fun .. When you decide to go faster , get a better hull and then upgrade the engine at that time .. Enjoy the lake boat for a few years first , then build you something to play with .. That is just my 2 cents ..
Yeah i know what your saying, Ive been there with a few cars Ive built over the years. I don't mind minor maintenance here and there, but def don't want to take it out and worry everytime i decide i want to drop the hammer about it. And with the engine i have i don't think id get that reliability with cast parts!
So, Ive come up with this build that should make some good power, and hopefully will be reliable. Ive been pricing out a 454 forged crank and they are almost twice the cost at the low end of what i can get a factory GM forged crank to do the 427 shortblock. And i trust a remaned GM forged crank more than a Chinese cast steel crank for the same ~300 bucks, and the reman crank comes with rod and main bearings, a set of L2300NF30 Speed Pro Forged pistons, there are the same as the old TRW forged and are on the heavy side but dam near bulletproof, a good set of file fit moly rings, and a set of Scat I-beam rods with upgraded ARP bolts will be more than strong enough, i was looking at a set of SGI rods on ebay, they offer the I-Beam for pressed fit pistons for 168 bucks for the set, or 255 for an H-beam set, but then they also recommend that you upgrade there cheap bolts with ARP and then your at the same price as the Scat and to be honest i trust the Scat rods more so ill go that route, then then needed machine work and having the assembly balanced, already have the 10qt Dooley oil pan, then was looking at the Comp Extreme Marine cam, 242/248@.050 with .572/.572 lift with the 1.72 roller tip rockers i have.
On the heads, i have compete comp cams/ARP upgraded parts for the vortec 454 heads, only stock parts left are the valves and at 2.062/1.72 was thinking about seeing what it would cost to upgrade them to 2.19/1.88 and these have 100cc heart shaped chambers and the intake runners are ~260-270 and actually have decent flow numbers in stock form, the bigger valves will help and then some minor port matching to my intake and the headers and they will support ~550, just heavy as hell! Also with the 16.80cc dome TRW's and these heads at zero deck height and a .040 head gasket im at 10.5-10.6:1CR, and with the cooler running temps in a boat and fully adjustable timing via the EFI i think i should be fine on 93 pump gas, and should be in the 450-500 range spinning a max of 6500.
I read a HotRod mag article where they pulled a stock stock Gen6 454 from the junkyard, put an edelbrock performer RPM air gap intake and 750 carb and MSD ignition, and with dyno headers and only a comp cams extreme marine 230/236@.050 .547/.547 lift on a 112, which is one step below the cam i listed above, with the stock 9.1:1CR and the needed valve spring upgrade, but still running the stock net lash rocker arms the engine made 428HP/507TQ. A little more compression and cam and i think your getting close to 500, maybe alittle more.
Also if i go this route, i cam have my Berk pump rebuilt and keep the aluminum impeller for now, or i think ill be fine, and not be dropping a ton on getting the pump freshened up and ready to go.
OK, sorry this got kind of long, but does this sound like a good plan for a fun, semi fast and reliable boat that will look awesome and should sound pretty dam good too!
