Devilman said:
SyTy Speed Shop said:
Yeah I'm thinking I'm gonna mount them solid just to keep things simple and I'll be the only one driving this beast anyhow. Lol
I also wanted to know if anyone has any experience with Dooley Enterprises oil pans? There is a used one on ebay that will fit my gen 6 Block and is a 10qt. Seems like a decent deal but no pick up tube.
I bought a used Dooley pan 5 or 6 years ago, but never put it on, lol... Main reason being I ain't pulling a running engine just to swap an oil pan. I just wanted more oil capacity over the 5 qt. front sump pan that's on it. That said, that small car pan been on it for the entire 11 years I've had the boat & I haven't had any issues with it so maybe I should just leave it alone. :cheesy: Doing some reading back then, I found there are better quality pans out there, but for the average lake boater wanting a large capacity pan I'd think they're probably ok. What is it going for? Any idea of what they are new?
Yeah, a new kit from Dooley is ~600 bucks! This pan on ebay is a BIN for 140 plus shipping and looks to be in decent shape just no pick up tube, which i think run around a 100 for a new one, so id still be less than half of a new kit.
I too have been reading that on a jet its a good idea to have larger oil capacity, but at what most of the kit run i wasn't willing to drop the cash and was just going to run my stock 6qt rear sump truck pan and maybe add a windage tray.
UPDATE: I called Dooley about the oil pan yesterday and found out that its not one of their performance oriented pans, but a production pan they produced for Mercury Marine and it will fit my Gen 6 block and a new windage tray and pick up tube for it will run alittle over a 100 bucks, i think it has 1 trap door to where the performance pan has 2, so im still thinking for the ~280 id have invested in everything i think id be much better off than my stock truck pan.
What do you guys think?
Also wanted to ask a question about CR, i will be running AFR aluminum heads and was originally thinking about keeping my static CR around 10:1 but been reading alot of build articles and it seems guys are getting away with over 11:1 with aluminum heads and 93 pump gas, so i was thinking about going with a different piston to get right at 10.95:1 and my plan is to run a 160 thermostat and with the EFI running closed loop and with knock sensors i should be able to control any detonation. I don't want to have to deal with octane additives and just stick with 93 pump gas.
Thanks
