Ok, i think ive got my idea and a plan for the interior of this beast. I want to keep it simple and as light as possible, and im going to build a sturdy but lightweight center console that will start at the back of the front buckets and go up to the bottom of the dash. Also, in an effort to keep things simple and smooth, im going to remove all the switches and key from the dash and on the original dash there will only be the steering wheel the speedo and the tach, i think im going to run the Autometer Silver Pro Comp Marine gauges,
http://www.autometer.com/gauges/marine-white.html
In the center console im going to mount the manual place diverter manual control so that it looks like a shifter, and the reverse handle next to it so that it looks like a reverse lock out lever on the old 4 speed shifters. Then on the front part of the center console that will go up and meet the bottom of the original dash, im going to mount the rest of the gauges, will be running water temp, oil pressure, volts and fuel level for sure, but also thinking about running an oil temp and fuel pressure since it will be EFI, and also a Wide Band O2 gauge to keep track of the AFR and it will make tuning alot easier, then below that ill mount the radio. The also use the back and sides of the center console to mount some speakers. Was thinking id make it the same width as the inside of the main stringers, using some lightweight 1/4 or 1/2" plywood and then fiberglassing over it.
Then run a fiberglass bench in the rear, and make some side panels to go the full length out of the same 1/4 or 1/2" ply and glass it over before adding some upholstery.
