Patchman said:At this rate, someone will be boating this coming spring! clap.gif clap.gif :smile17:
The poly will be fine for the PB, and the epoxy will go over the top of it nicely. If you are using Epoxy there is not need to use the mat as the epoxy doesn't have the styrene to break down the fibers in the mat and it will just soak up a bunch of resin. Just use the cloth or roving. For the tops of the stringers with the epoxy you just need a light covering nothing heavy.Longstr said:I am gonna see how this peanut butter works out I will keep u all updated, also won't b using any poly resin to make peanut butter.
ChryslerJet said:The poly will be fine for the PB, and the epoxy will go over the top of it nicely. If you are using Epoxy there is not need to use the mat as the epoxy doesn't have the styrene to break down the fibers in the mat and it will just soak up a bunch of resin. Just use the cloth or roving. For the tops of the stringers with the epoxy you just need a light covering nothing heavy.Longstr said:I am gonna see how this peanut butter works out I will keep u all updated, also won't b using any poly resin to make peanut butter.
Unless its bad and doesn't setup it won't be an issue. What doesn't work is putting poly over epoxy because the poly just won't adhere to it well at all. Putting epoxy over poly well epoxy adheres to almost everything. Epoxy is also a little more forgiving if you don't get it quite right but takes longer to setup. Poly sets up quick so if you don't have everything ready to go and it sets up its wasted.Longstr said:ChryslerJet said:The poly will be fine for the PB, and the epoxy will go over the top of it nicely. If you are using Epoxy there is not need to use the mat as the epoxy doesn't have the styrene to break down the fibers in the mat and it will just soak up a bunch of resin. Just use the cloth or roving. For the tops of the stringers with the epoxy you just need a light covering nothing heavy.Longstr said:I am gonna see how this peanut butter works out I will keep u all updated, also won't b using any poly resin to make peanut butter.
My concern is using poly for peanut butter and it letting go from stringer or joints someday
ChryslerJet said:Unless its bad and doesn't setup it won't be an issue. What doesn't work is putting poly over epoxy because the poly just won't adhere to it well at all. Putting epoxy over poly well epoxy adheres to almost everything. Epoxy is also a little more forgiving if you don't get it quite right but takes longer to setup. Poly sets up quick so if you don't have everything ready to go and it sets up its wasted.Longstr said:ChryslerJet said:The poly will be fine for the PB, and the epoxy will go over the top of it nicely. If you are using Epoxy there is not need to use the mat as the epoxy doesn't have the styrene to break down the fibers in the mat and it will just soak up a bunch of resin. Just use the cloth or roving. For the tops of the stringers with the epoxy you just need a light covering nothing heavy.Longstr said:I am gonna see how this peanut butter works out I will keep u all updated, also won't b using any poly resin to make peanut butter.
I am with Cliff on this, The extra stringers won't hurt anything but will add some extra weight. If you can do it then go for it extra strength is always good.Crusader said:Is this the boat you're building now? Or do you want to make your current boat like the one you've pictured??
If you're able to do so, I'd put a center stringer in.
