EMBRACETHEHATE
Actually used a fiberglass rod and welded it to the holley.
Sent from my DROID RAZR using Tapatalk 2
thought I did scoop has a plywood one in it. Just need a flame arrester and longer boltDuanehydro said:So you need to build a mounting tray?
He's adjusting nicely! :smile16:EMBRACETHEHATE said:Actually used a fiberglass rod and welded it to the holley.
Did you buy that from Hellin? :smile21:EMBRACETHEHATE said:thought I did scoop has a plywood one in it. Just need a flame arrester and longer boltDuanehydro said:So you need to build a mounting tray?
no Brent Nunn actually made me a helluva deal.Patchman said:Did you buy that from Hellin? :smile21:EMBRACETHEHATE said:thought I did scoop has a plywood one in it. Just need a flame arrester and longer boltDuanehydro said:So you need to build a mounting tray?
Dude, you forgot about the weakest force in Nature.........Gravity :smile30:DrumZilla said:For me all my boats were different. As you trim the jetavator up you'll feel the boat lift and you'll gain speed. And theres always a sweet spot. I can always feel it... And it's sweeeeeet....2ft off the water is a good place to start..You'll probably get some mechanical reasons on here too...like the horse power ratio to the RPM compared to the centrifugal force of the boat hull divided by the spinning ratio of your impeller plus the length and weight of your boat....I got that off The Big Bang Theory.... my 2 cents..
DrumZilla said:#2 yellow pine...Come on to Home Depot and I'll fix ya up with some #1 lumber... bling.gif
EMBRACETHEHATE said:Serious note. Wheres the best "trim" setting for the jetovator? As far as the rooster tail. Ive heard 2ft off the water is ideal. Does it just depend on the boat?
sent from my galaxy tab 2
