DAMN!! 6.2 liter Caddilac CTS-V motor on an outboard kicking out 557 ponies! That would go well on a Liberator pickleforks.
http://www.youtube.com/watch?v=60YqcCBtBuU
Or on SimplyOranges Alley Cat he has for sale.blazeracer said:DAMN!! 6.2 liter Caddilac CTS-V motor on an outboard kicking out 557 ponies! That would go well on a Liberator pickleforks.
It is just right, CAV plate is even with keel. Never heard of the Prop shaft even with the Keel???blazeracer said:OK, had a guy come by the shop the other day and said the motor was too low. Ideally the prop shaft should be even with the keel. I guess a jack plate will take care of this?
http://compare.ebay.com/like/160971072224?var=lv<yp=AllFixedPriceItemTypes&var=sbar
Rated up to 175 horse, my motor is a 150.
Gas-Hole said:It is just right, CAV plate is even with keel. Never heard of the Prop shaft even with the Keel???blazeracer said:OK, had a guy come by the shop the other day and said the motor was too low. Ideally the prop shaft should be even with the keel. I guess a jack plate will take care of this?
I'll go along with up to 2' above the keel, but not prop shaft even with keel. I can't tell from the Picture exactly where it is, put a straight edge on it, even is good, 1-2" up is ok but if you go higher it will cav on plane.Crusader said:He's right James. Ideally the cavitation plate should be about two inches above the keel.... Right now theres a ton of drag when you're on a plane as the Cav plate is partially submerged.
Also....you'll want to look into a more modern propeller too......that way you'll get more stern lift and less cavitation. Ditch the whale tale......that's a band aid to the real problem....an improperly propped boat.
With 1/2 of his prop in the water he better be running an Air cooled Engine!Crusader said:That's true....ideally you only want 1/2 to 3/4 of the prop in the water.
Correct.NMliberator said:Forgot to mention that I have low water pickup. Without the l/w pickup your not gonna be able to go anywhere near that high.
KONA said:if I'm not mistaken, james, the stainless prop is a 14" pitch, what horsepower is you motor?
Crusader said:James....to properly prop a boat you'll need to know the max WOT RPM range for your motor and also the gear ratio of your lower unit.
There's so much you need to know in order to get the prop correct or else you'll porpoise, cavitate, take a long time to plane etc etc......
Is there a manufacturer stamped on the stainless prop?
