Last Mohican said:
Not worth it IMO when a new cam and lifters can be had for $114. Maybe on a cam with a profile that you really want and you know the history but not on a stock or near stock cam out of a motor with an unknown number of hours that was pulled to be rebuilt because it was worn out.
$114?? I don't know where you get your cams from. This one was $109 from Summit, NEW cam and lifters. Plus that Crusader was the slowest boat on the lake. Why the hell would I want that cam in the JYD hot rod!?!?!? LOLOL
Becket
Not here to debate, just give my Opinion, Correct, cams can be had for very little money and unless you are sentimentally attached to one there is no reason to not replace it at rebuild, However, It has been my experience that FT cams can be reused successfully if you #1; Put the used Tappets back on the lobe that they came off of or #2 Replace them with new Tappets (I suggest replacing them) (lifters).
I Build lots of Big Diesels and the Cams are NOT cheep for these so I reuse the original cam as long as it is not Damaged, I have done this MANY MANY MANY times with absolutely NO Cam failures. I DO replace the Tappets as they are not all that expensive in comparison to having a used one fail.
Treat it like a complete Cam change and run the propper Break-in for the Cam like it was a new one and you will have no problems.
This is my Opinion and experience, take it for what it is worth to you, Could save you a Couple Bux for some much needed and ever so nice  bling.gif :smile30:
I would also like to add this, B&G Pre-lube, This is the Finest Pre-lube that I have ever used. this stuff is BAD A$$! Been using it for YEARS!
http://www.bgprod.com/products/special.html
And if it was an expensive cam I would go that way, but for what this ones costs, it's new with a little more aggressive specs that the one Cliff has assuming it's a stock Ford jet boat cam.
I agree.
That number came from the link you posted to Summit.  $114.95  :Dunno:
Then that part is settled. Motor should be ready by the end of next week. A mild performance cam this time that will be nitrous happy.
http://www.summitracing.com/parts/SUM-K3501/
The official color names of the paint being used are...... Ford Grey and Ford Blue.
Hell yeah. It's on sale at tractor supply cause they are getting rid of it I guess. I got like $60 in paint so far to include the hardener for it so it will be fuel resistant. Junk yard dog gotta get on the water for under $2k. I splurged on gauges so gonna have to make it up somewhere.
Who around here can TIG? One of the water bungs on the $200 headers needs to be welded.
Jasson's brother.  Take it to Cedar Creek and give it to him there.
That's the plan for the CJ too under 2k to 2500.  Right now sitting at $1200.
