Captin Hazlewood
Last Mohican said:I believe Stacy is pointing out that the engine is forward facing and driven off the crank snout instead of the flywheel. That would change the direction of torque twist in relation to the prop... except then wouldn't he need to run a reverse prop? s***. Now I am confused. I will stick with the jets and sit in the corner with my mouth shut on this V-drive stuff.
ya got ya... I did say propeller torque... All a jet has is engine torque... in a jet I don't think it matters much until you get to very high HP and Torque, it does not have the added and more pronounced effects from a propeller such as paddle-wheel and torque. In the application where the engine is forward facing and driven off the crank snout... unless the motor runs backwards or the gearbox reverses the direction I think this application would use a left hand rotation propeller. A left hand rotating propeller is going to push the Port sponson up and the Starboard sponson down... thus the driver sits on the Port side of the boat... likewise the reverse is true of a right hand propeller...
Port goes down... starboard goes up.... anyone wanna guess where the driver sits?
Want to talk about twin screws next?
