TexasJet
FL350 said:Is this for the blown jet boat?
Naw, I'm only bringing the Baja. There won't be any competition for the blown jet. Just kidding, it's NASTY BOY.
sturat said:Use your ratchet on the trailer and build some heat, then close off your water valve to the motor some. That will restrict the water to the motor and keep some heat in the oil.
Just cruise around, like said earlier, you can go down river aways and warm it up. :grin:sturat said:Then you can unbolt the driveline, it is just a few bolts. If you do not want to do that then just cruise it for a bit before hand.
Patchman said:Just cruise around, like said earlier, you can go down river aways and warm it up. :grin:sturat said:Then you can unbolt the driveline, it is just a few bolts. If you do not want to do that then just cruise it for a bit before hand.
FL350 said:Are you running a pop off with a solid driveshaft?
TexasJet said:Cruising around sounds good. What time is everybody getting there? Please don't say 9 or 10 AM. I'm hoping around noonish.
Devilman said:I thought I read somewhere that it was difficult to build heat in an engine when running salty water thru it... :huh: maybe I'm thinking of something else...
lol :evil: :grin:
lol :evil: :grin:
Mike S said:Devilman said:I thought I read somewhere that it was difficult to build heat in an engine when running salty water thru it... :huh: maybe I'm thinking of something else...
lol :evil: :grin:
No that aint true. It's just as easy to build heat! Jeff just run the boat a little or let it. Idle around out there like patch said the oil temp will be hotter then the water temp, so when you start seeing heat in the motor (and YOU WILL) you'll be fine! What does the normal temp run? I always ran mine at 120-130 even in the summer! And the oil temp was still around 175-180 in winter and 200 in summer!! With those water temps!
TexasJet said:STOP IT!!!!!!!!!!!!!!!!!!
You are sooooo your avatar.
Mike S said:No that aint true. It's just as easy to build heat! Jeff just run the boat a little or let it. Idle around out there like patch said the oil temp will be hotter then the water temp, so when you start seeing heat in the motor (and YOU WILL) you'll be fine! What does the normal temp run? I always ran mine at 120-130 even in the summer! And the oil temp was still around 175-180 in winter and 200 in summer!! With those water temps!
TexasJet said:Mike S said:Devilman said:I thought I read somewhere that it was difficult to build heat in an engine when running salty water thru it... :huh: maybe I'm thinking of something else...
lol :evil: :grin:
When fully warmed the water temp is around 150.
Devilman said:TexasJet said:STOP IT!!!!!!!!!!!!!!!!!!
hahaha, winter time shenanigans. :grin: You'll be fine.
I was just messing with Jeff, there ain't nothing wrong with that water. :smile14: :smile17:
Ol Kona was right about the sensitivity level it appears... lol :grin:
Patchman said:With all the rain lately, it mite be closer to fresh! :smile17:
DISTURBED said:Patchman said:With all the rain lately, it mite be closer to fresh! :smile17:
Did KONA hack into Patch's account???? :smile26:
