First thing i would do is check to see if the vent is working properly on the fuel tank or tanks! Easy check is to pop the lid and run it a bit to see if it stalls. My Taylor SS Did that a bunch when i put that blown motor in it. Pretty much running out of fuel because of no vent.EMBRACETHEHATE said:Today my boat ran great except for 2 times it stalled after I was in it pretty good. I didn't instantly let off I did it smooth. The first time it took me 15-20 mins of sitting to get her fired up again. When I finally did lots of steam came outta the headers. The second time it started instantly but again blew a lot of steam. Could my t fitting be going out? Seems like its not shutting the water off fast enough maybe?
After reading all the horror stories I'm thinking I'm just going to get away from water injected headers and running dry. Seems a lot less bs to mess or worry about. Any ideas?
Sent from my DROID RAZR using Tapatalk 2
thanks! Will do!oldbuck40 said:First thing i would do is check to see if the vent is working properly on the fuel tank or tanks! Easy check is to pop the lid and run it a bit to see if it stalls. My Taylor SS Did that a bunch when i put that blown motor in it. Pretty much running out of fuel because of no vent.EMBRACETHEHATE said:Today my boat ran great except for 2 times it stalled after I was in it pretty good. I didn't instantly let off I did it smooth. The first time it took me 15-20 mins of sitting to get her fired up again. When I finally did lots of steam came outta the headers. The second time it started instantly but again blew a lot of steam. Could my t fitting be going out? Seems like its not shutting the water off fast enough maybe?
And if its stalling while running a pretty good clip across the lake,,,well you got plenty of water in the headers when it dies and it does not have time to blow it out like it would if it were still running and the T valve shuts at 1300 rpm. :smile30:
has new filters did that after the carb rebuild. New fuel line as well. I have a mechanical pump, forget what brand.$HAG NA$TY said:Hey also, Stupid little things like fuel filters can be really dirty. Its amazing what a brand new fuel filter will do!! I have 2 filters.. 1 going off each tank. check it out couldnt hurt, and its a cheap part. Also what kind of fuel pump do you run? Mechanical or Electric? (personally) I've had nothing but problems with electric fuel pumps.. they work great for a while, then they just go out, always replacing them. my buddy had the same problem as what it sounds like you are describing.. we changed out the electric pump and put a stock mechanical pump in and ran perfect again. I run a Mechanical pump on my BBF. Just go through the basics and you'll figure it out... :smile17:
Totally would but i do not trust the trailer, thats on my list to do. Its fine towing 2 miles to the launch ramp. 100+ may end in blown bearings, wheels flying off, maybe even death.DrumZilla said:Bring it to Somerville this Sat. :smile30:
lake lbj, in marble fallsDrumZilla said:Gotcha... Where do you go that's two miles from you ?
I'm waiting on my uncle to get one of their ski boats out of the lift. Then trailer will be worked on. New bearings, paint, bunks, lights, and carpet.Patchman said:Death would not be good. Get that trailer fixed man, boating season is upon us and there are gatherings all over the place. Got to be road worthy! :smile16:
EMBRACETHEHATE said:I'm waiting on my uncle to get one of their ski boats out of the lift. Then trailer will be worked on. New bearings, paint, bunks, lights, and carpet.Patchman said:Death would not be good. Get that trailer fixed man, boating season is upon us and there are gatherings all over the place. Got to be road worthy! :smile16:
haha ya, ill figure it out. I need to tear into this thing and get familar. Dumb question what weight oil should i run? 10w30? Or something thicker?KONA said:hard to say now adays, but you should be able to get gaskets,
not gonna get to much input most guys are head to the lake :grin:
