Devilman said:Going back a little, what was the idea for what you did with the center stringer... with the foam block, etc... Since that is where any accumulated water would naturally pool up, that foam/glassed area will withstand possible deterioration better than just wood I guess? Still actually drains to the bilge I would assume.
Longstr said:Basically instead of having two holes in the last floor divider one on each side of the center stinger, I cut a small portion of the wood out of the center stringer, added a little pour foam to that section which is encapsulated, then drilled my holes thru the foam to meet in the middle, coated everything in resin. I guess my thought process was if there was no wood around the holes I had to drill it couldn’t rot.
Devilman said:Longstr said:Basically instead of having two holes in the last floor divider one on each side of the center stinger, I cut a small portion of the wood out of the center stringer, added a little pour foam to that section which is encapsulated, then drilled my holes thru the foam to meet in the middle, coated everything in resin. I guess my thought process was if there was no wood around the holes I had to drill it couldn’t rot.
Gotcha, that makes sense. Have you ever run across any that didn't have a drain there? The knucklehead that did my floor did not put one in mine. So even with a new floor, with gelcoating & no carpet, it still makes me wonder if water can accumulate under there & then be trapped.
Longstr said:Yes, the Taylor I redid, I didn’t put a drain there I went back and forth about it however I decided since I was reduingn it all and sistering everything to the floor not drilling a single hole thru it I decided this would be the best approach, I put foam back in it too. This boat has holes thru the floor for gas pedal so it’s gonna leak there. Also condensation from a 120 degree floor to a cold hull in the water will build up. I am currently nsodering putting a drain plug in this hole? Not sure yet
Longstr said:Bingo Cliff! That’s the way it should be done I believe u and I discussed this same issue when I was doing the SS
Devilman said:Cliff didn't share that info with me, I musta been on the pay no mind list.... :smile24: :smile28:
