Cash Hole said:Brazos River Rat ( Billy ) said:Once you get it dialed in or off the Dyno , will you share you carb information with me . I am running E-85 in my 555 Chevy 13.5 to 1 compresion and still trying to get it dialed in . This weekend , hoping to get closer with the O2 sensors hooked up .
I have a BLP 1050 Domiantor flowing 1289 cfm with 132 jets in it .. Just like to see what some one else come up with for jet sizes ..
Sound like a monster you are building ..
I'll be more than happy to share. Chris is doing my grind for E-85. He said it will work with race gas but not as well as the E-85. I am also at 13-1. Have you looked at raceone85.com? Some good info and help over there.
Alan
I have check that site out also . Mine does not flow as much as your head . Yelvey told me that mine are flowing just over 400 the last time he checked them . I do not have a custom grind cam this time ,It a V-Drive cam from Isky for 4500-7500 rpm . # 396732 Isky
The BLP carb is close to being right , at first it was lean on the bottom end and with some air bleeds and some bigger squirters , that problem is solved . I just need to get it leaned down enough now , Last outing at mid throttle , O2 reading was at 5.5-6.0 not sure what it should be at part trottle with a dominator feeding it .The O2 reading at WOT pass should be 8.0-8.5 readings making a WOT pass .
Hopefully Sunday will be my first WOT pass with the this new engine and I can adjust from there ..
