SyTy Speed Shop said:Ok, yeah i was looking at one at wally world with a snap top lid for like 9 bucks. On the battery itself, is an actual marine battery needed, or just works better/last longer? Trying to find a good deal on a battery as im gonna get this thing in the water and hopefully running next weekend!!
Probably some good advice there. :smile16:customtouch said:A deep cycle will work better if you plan on having a decent stereo system in it but as previously stated, any battery would work. If it were me and I was just taking the boat out to see if it runs, I would just borrow one from one of your other vehicles for the test run before stepping out and buying one. You may need that money for more pressing matters on the boat. A good battery is usually one of the last things you will need for the boat. JMHO.
Chevy2184 said:Make sure that carb is linkage is working 100% freely before you try to fire that puppy up so you don't run into any surprise...
Sent from my shop setting in my boat making motor noises
SyTy Speed Shop said:Chevy2184 said:Make sure that carb is linkage is working 100% freely before you try to fire that puppy up so you don't run into any surprise...
Yeah i decided that i was just going to replace it. I found a deal on a Carter AFB 750 carb for 58 bucks that needs a rebuild, and 45 bucks for the rebuild kit and these carbs are super easy to work on so im just gonna ditch the quadrajunk that's on there.
Once i get the carb swapped out and get it running, im gonna swap out the old points for an HEI to simplify things and be more reliable. I can order a complete billet aluminum HEI with a 65K volt coil on eBay for 50 bucks, yes its made oversees but the quality is actually pretty decent as Ive used them before for other engines.
Hoping to get it splashed before the summer is over.
Chevy2184 said:SyTy Speed Shop said:Chevy2184 said:Make sure that carb is linkage is working 100% freely before you try to fire that puppy up so you don't run into any surprise...
Depending on what dizzy you have in their you could prob get a kit from petronix to drop right into your stock dizzy and do the same thing? I think their flame thrower 3 kits even have a built in rev limiter...
And good call on ditching the q-jet... Just remember to soak that afb in some chemtool for a couple of hours before you throw your new kit in it... It will get all the goodies out that the air hose and carb can can't get...
Chevy2184 said:If you are talking stock or a little higher than stock horsepower stick with the mechanical fuel pump...lot less stuff to worry about getting wet or hot or making noise... And will go forever... If it was a high horsepower type deal then yeah... Are your fuel tanks aluminum? If so this stuff works like a champ!
It's like 30$ a gallon from Amazon...
Brazos River Rat ( Billy ) said:I just bought a new CLay Smith mechanical pump for my boat .. They told me is would handle overs 1000 HP easy , closer to 1200-1300 on gas per their web site ..1/2 inch line in and out .. Cost is 175.00 plus shipping .. I should be getting it today .. I would run a mechanical any day before I switched to an electrical .. I am not a fan of electrical fuel pumps in a boat ..
It is over at EO's and he is looking at it .. Not sure how to get it apart and then back together .. EO is going to tackle it and then Trey will get it from him for a back up pump .. I think all the problem was that they did not get the two screw in the middle section tight enough from the factory .. One was pretty loose..jimsplace said:Brazos River Rat ( Billy ) said:I just bought a new CLay Smith mechanical pump for my boat .. They told me is would handle overs 1000 HP easy , closer to 1200-1300 on gas per their web site ..1/2 inch line in and out .. Cost is 175.00 plus shipping .. I should be getting it today .. I would run a mechanical any day before I switched to an electrical .. I am not a fan of electrical fuel pumps in a boat ..
Did you give up on your Carter pump?
