Looks good
SimplyOrange said:not bad for a rookie, starting on the rear seat today. we are really slow to make sure it doesnt mess up, checking things 5 times before i cut or stitch, i did the designs and measurements and my fiancee does the sewing because i quickly learned that i do not know how to use a sewing machine...
blazeracer said:SimplyOrange said:not bad for a rookie, starting on the rear seat today. we are really slow to make sure it doesnt mess up, checking things 5 times before i cut or stitch, i did the designs and measurements and my fiancee does the sewing because i quickly learned that i do not know how to use a sewing machine...
That's totally awesome!! Cliff, you NEED this.
CJ is wondering if maybe Cliff is thinking since the Crusader can't blow the tops off his passengers that maybe he can suck them off with a scoop. CJ still doesn't want a ride in the Crusader.Crusader said:blazeracer said:SimplyOrange said:not bad for a rookie, starting on the rear seat today. we are really slow to make sure it doesnt mess up, checking things 5 times before i cut or stitch, i did the designs and measurements and my fiancee does the sewing because i quickly learned that i do not know how to use a sewing machine...
Yep, you are correct...I was thinking the same thing!
A scoop on the Crusader would look awesome!!!!
ChryslerJet said:Yes I do want all the secrets of the universe. BTW I can share the secrets of the automatic transmission.SimplyOrange said:ChryslerJet said:Looks good, where you getting the foam for the seats and what kind are you getting?
you want all of my secrets dont you?
Eva-dri marine foam. i just ordered all of the stuff to cut and sew my own upholstery. if i get it figured out the only thing on the planet i have not mastered is automatic transmissions.i think i have worked on everything else.
http://www.onlinefabricstore.net/foam-and-pillows/foam/outdoor-foam/eva-dri-foam.htm?N=10685
