DiamondJim said:If you get Kona's bell housing, will you still need the front mounts? And the PTO adapter? Just let me know, I'm in no hurry and wont be at my shop for another week, then I'll be busy putting the Glastron together for Welshfest. Hope you make that pull, I think Kona will be there.
Looks like there isnt a way to bolt rear mounts to the stringers from the picture? Thats probably why it had that type of bell housing.blazeracer said:Oh no, I think I need this type bell that attaches to the pump housing. That's what's in my Glastron, and this pump has the same lip the bell mounts to. Unless there's another way these things mount. How does that bell attach to the boat? The front ones would probably work.
Here's a pic of the pump area.
Motor Head said:If you don't have a problem with coil binding you may have a problem with valve float becaus lack of spring pressure.
WAFOBABY said:James while you are working on the bottom end pull those LOADER screws out and I can bring you the grade eight screws that you can use to drill and tap them all the way threw they are 5/16 by 1 1/4 black oxidize hex head with lock nuts I have a hole box full. Those loader screws will prob be a mutha to get out.. Let me know. What color are you going to paint this one? Also just FYI ET automotive is trying to get rid of all there jet boat parts so you might go ever there and see what they have and can prob get a good deal on it. I know they had a set of seats over there as well. If not I can ask my brother what he did with his two front seats he took out of his boat and see if he want to get rid of them. 2000.00 is going to be cutting it close. I know my brother has 1200.00 in his as you see it is how he got it less seats and scoop and intake. 1000.00 and he was on the water. But his came with a motor also.
DiamondJim said:Has ET got a web site, so the rst of us can see what they have, I know, Randall, Patch and I are jet boat parts hoarders.
