sturat said:Like a turnbuckle
okay, gotcha....I can get one of those at lowes....
Last Mohican said:Smiley's has a nice selection of Heim joints and turnbuckles.
Crusader said:Last Mohican said:Smiley's has a nice selection of Heim joints and turnbuckles.
Is that the hot rod performance store you and Brent went to a few weeks ago?
Last Mohican said:Between the alignment and the oil I bet that is your problem. Fix the alignment on the stand where you can see it, add a tur buckle with heim joints and the rebuild should fix the oil issue. Problem solved.
Crusader said:Last Mohican said:Between the alignment and the oil I bet that is your problem. Fix the alignment on the stand where you can see it, add a tur buckle with heim joints and the rebuild should fix the oil issue. Problem solved.
Ya, I hear ya....just planning ahead while the motor is still in the boat...... which will be pulled out this evening.
On another note.....bearings. Should I use teflon coated bearings with the crank? Is that just a high performance motor trick or would I gain any reliability by using them?
Crusader said:I think the motor is a marine motor...it has brass freeze plugs installed.
How can I tell if my heads have been worked/machined for optimum performance??
Last Mohican said:Double gasket is a common solutions for leaking exhaust. Not real sure how much it helps on a boat with logs but it was a big help with a set of $79 Headman headers from Super Shops back in 1988. LOL.
Brian would know if those heads were worked. You can tell by looking at them. It's kinda hard to put into words but you would know it if you saw the difference.
