Patchman said:I see where on injected engines, they have good luck with it. Doesn't appear to be nearly as challenging as carbs! I know that doesn't answer your question though! :evil:
Because of fuel system design, and the ease of setting an accurate fuel curve that is monitored by electronics! That's why manufacturers include fuel sensors that can detect E-85 and switch the tune for dual fuel cars! :smile30:jimsplace said:Patchman said:I see where on injected engines, they have good luck with it. Doesn't appear to be nearly as challenging as carbs! I know that doesn't answer your question though! :evil:
Why would e85 be less challenging with injectors than with carbs?
Patchman said:Because of fuel system design, and the ease of setting an accurate fuel curve that is monitored by electronics! That's why manufacturers include fuel sensors that can detect E-85 and switch the tune for dual fuel cars! :smile30:jimsplace said:Patchman said:I see where on injected engines, they have good luck with it. Doesn't appear to be nearly as challenging as carbs! I know that doesn't answer your question though! :evil:
Bert88 said:I run e85 on blown injected sbc and I love it !! I was running alcohol before and seems to be about the same performance except for way cheaper!
Brazos River Rat ( Billy ) said:Tim---They can set it up for E-85 when you purchase the system from Edderle, I would have them calibrate it for you and flow test it .. Then it would be just a matter of fine tuning it , the tuning window is a lot bigger with E-85 than gas also ..I agree , changing oil ever weekend out would suck and be expensive .. Plus having to drain the system and then fog it with WD-40 every time sucks also , unless you run some race gas through it before you shut it down for the weekend .. Of course just setting on the trailer .. You will need to rig up a primer system also .. That would be a sweet set up ..
Patchman said:I forgot! Defaulting back to the car world! Well it is easier to replace one jet rather than 4 or 8! :smile30:
Man they have some cool stuff! :smile16:Chevy2184 said:I'm pretty sure bert88 got his from good vibrations? He should chime in here before long?
