Starting this for a little (yes 14'6" x 45" bottom) semi-flat boat (vee in front, flat in back, looks like a really old Lund boat) that I am fixing up for using down at the River. I know it's not a "Hot Boat", but figured this would be a good place to get some input/help and put pictures of it etc.
The story behind it is a friend got it for $100 cash. It floats, and engine runs. It's a console drive with 25HP 1985 Evinrude E25ECOC outboard 2-smoke motor. The motor is in fantastic condition. The boat hull is not.
The things I need to do to it are as follows in this order:
1. Replace trailer. It has some GHETTO-NECK built trailer under it, will post pics, good for some LULZ for sure! I have a regular "jon boat" type trailer that had a 16' Baja Ski boat on it when I got it, put a proper trailer under the Baja years ago, so I have this trailer leftover, will work perfect for this boat. Needs some new wheels tire and some hardware and paint.
2. Repair the Hull. It's got a few spots that are questionable, and one small leak, I can see the water coming in, but could not see the actual hole once I got it back out of the water.
3. Paint Hull. It's ugly, been painted all different colors since the 60's or whenever it was originally built. Got a little bit of old paint left to strip off then will spray it Army Green, trailer as well, same color.
4. Deck it. Rebuilding the interior of it, in the "Bass-Jon" type fashion, but more with "boating" in mind rather than fishing, I am not a good fisherman.
5. Get it setup and running / driving right.
I am sure when it's done it will be a neat little boat to cruise the River in at a very low fuel consumption rate. Might get me into the water more this year than last year, I just couldn't afford much gas in the Jet last year because of this economy. I expect it to be worse this year.
Will get to posting up a few pics in just a moment.
