spd500 said:DISTURBED said:http://www.aircraftspruce.com/catalog/appages/ps890.php
Am I reading it wrong ? Looks like that stuff is for sealing fuel tanks ? Not cheap either :smile13: :smile13:
spd500 said:so , I could use it instead of resin to glass the mounts down , but I would still have to use mat ? I was kinda hoping for some quick easy glue the bracket to the bottom of the boat kind of stuff , but it sounds like I might be better off to go ahead and glass it in right .
customtouch said:spd500 said:so , I could use it instead of resin to glass the mounts down , but I would still have to use mat ? I was kinda hoping for some quick easy glue the bracket to the bottom of the boat kind of stuff , but it sounds like I might be better off to go ahead and glass it in right .
I will call you tomorrow.
spd500 said:Ok, so what are opinions on the transom adapter ? I was told that you just need a gasket and to put grease on the gasket . The only one I have ever had apart didn't have a gasket , it had silicone , so I put it back on with more silicone . If I ever have to take it apart I don't want to screw up the new paint , so I am hesitant to use silicone unless it is neccessary .
spd500 said:I was thinking I would make a gasket for it . The gasket material that I have is the really thick stuff like what they use for the gaskets that you buy for the intake or transom adapter . I am going to go buy the bolts , so length will not be an issue . Like I said , I mainly want it to be right .
KONA said:spd500 said:I was thinking I would make a gasket for it . The gasket material that I have is the really thick stuff like what they use for the gaskets that you buy for the intake or transom adapter . I am going to go buy the bolts , so length will not be an issue . Like I said , I mainly want it to be right .
berckley pump, i have those gaskets, if you want them and will be for the shipping you can have them, and here's an idea, for the transom adapter, what if you use that soft weather stripping, you know the type that looks like a small cord, i use it on all kind of things to seal up..
Devilman said:spd500 said:I was thinking I would make a gasket for it . The gasket material that I have is the really thick stuff like what they use for the gaskets that you buy for the intake or transom adapter . I am going to go buy the bolts , so length will not be an issue . Like I said , I mainly want it to be right .
makin your own & startin with fresh bolts, it should be fine. I want to say the one that came with the rebuild kit was rubber, pretty thick too.
You gonna put the o-ring seal in there, to seal the transom adapter to the bowl? Liquid dish soap will be your friend on that deal.
spd500 said:That is going to get a healthy bead of silicone . I have heard bad things about those o-rings .
