If you have not already been told, you will probably want to let the clear cure for at least a day or two before you start on it again. You will want to lightly resand "all" of the boat before you start laying your tape because the overspray from the clear will be heavy and stuck everywhere. I am not sure about DuPont, but many of the urethane clears are sensitive to re-coating base on top of freshly sprayed clear so I would try to not spray the blue too wet and allow plenty of flash time between coats. You should be fine as long as you don't over saturate it. P.S. It looks pretty good so far.
