spd500 said:What we are thinking of for the custom exhaust is kinda like a cross between a header and a water log . Basically a 3" stainless pipe with the 1&7/8" stainless pipes to go out to each cylinder welded onto it , with a 4" stainless pipe around it where the water will flow . The same basic idea of a log , with the same flow capabilities of a header . Hopefully if I go this route it will flow enough to be able to just add the turbos when I am ready without having to redo the exhaust to support the turbo setup . What do y'all think ?
Last Mohican said:spd500 said:What we are thinking of for the custom exhaust is kinda like a cross between a header and a water log . Basically a 3" stainless pipe with the 1&7/8" stainless pipes to go out to each cylinder welded onto it , with a 4" stainless pipe around it where the water will flow . The same basic idea of a log , with the same flow capabilities of a header . Hopefully if I go this route it will flow enough to be able to just add the turbos when I am ready without having to redo the exhaust to support the turbo setup . What do y'all think ?
That is pretty much what Impatient1 did.
http://www.performanceboats.com/jet-boats/62463-wasted-incomes-lsx-into-avenger-jet-boat-build.html#post1058753
spd500 said:It is pressed with a roll pin , but the bottom half of the dipstick is a different material than the top half . I just figured it was easy enough to drill the marks and not mess with it . I sure would hate to have it fall into the pan .
Ok , just wondering . I have not really been planning on using a sealer because I was told that I didn't need it with the products that I am using . But I do agree on the extra once over to make sure there are no spots you missed before painting the boat . I am going over mine block sanding now and hopefully it will be straight enough to paint by the end of the week . I am in no way a professional or even very experienced at this stuff , so it probably takes me alot more time than it would take you or any other professional . I am sure even though I am putting all the hours into trying to d othe best I can it will still have some areas that could look better when it's all finished .Malibu Surfer said:I can't speak for PPG as their out of my budget usually unless customer requests it, but if it's a primer/sealer I'd say your good to go. If your jobber (that you trust) says your ok, go for it. (I'm a Valspar/ProSpray guy - always had good luck with their products).
Personally I use just a primer/surfacer, then a sealer coat after I'm happy.
I do this for two reasons, If I have a low or high spot my primer surfacer that I may have missed, it will fill hopefully, and if not, the sealer will. My 2nd reason is just one more complete look/see at the hull (or panel). I do it this way as I am 100% sure I have no sand scratches that will show thru. That is just me, but my #1 pet peave with paint is sand scratches.
I am not a production shop, so I have the time to do one more step to insure I'm happy, and customer or myself will be happy...
