ok so i put this all back together this morning... used far less silicone that i thought i would think.gif
I put the bowl gasket on "dry", and torqued the bowl bolts to 75, siliconed around the bowl , on the transom, and on the adapter sufaces..and into all the bolt holes in the transom... then smooshed the transom adapter in place and bolted it up, got the bolts pretty tight in my opinion... i just tightened tilll i heard wood start to compress.siliconed around the inside edge of the bowl, and on the inside edge of the adapter... then i siliconed the outside of the bowl where it meets the transom...and put a good bead around the out side edge of adapter.
i let it cure up for a couple of hours...then repeated the process and smoothed everything out. installed the cables and put silicon on the reverse cable where it goes through the bolt since i dont have a gasket here either.
all in all i feel fairly confident that this is going to work. as long as that bowl seal where the bowl meets the propshaft is ok...
So, which one of these lubricants should i put into my bowl and then seal up? and does it look like i re-assembled this correctly? my steering seems tighter. but still smooth.
should i give it a light coat of some color so it doesnt look so sad?
