The hot water heater area is a mofo!!! The last one we bought there was a foot of the floor rotted out from the outside wall inwards.. Problem we had was clearance between the heater tank and the floor and trying to replace the floor and also give it more support. You cant put jack chit inside on the floor! it all has to go outside and under the black skirt they staple on the bottom of the floorKONA said:oldbuck40 said:Well that aint real bad! least you still got some wood to look at! Looks like your getting an early start! The few i have done there was nothing but the tin,,you had to use your imagination on the rebuild!KONA said:here are a few pics to show my starting point, this is pics of taking the utilities doors of the side and a pic of the bottom skin being pulled back, leaving this thing sitting outside and it raining two to three days out a the week this past year, has really got it wet under the skin
The hardest and time consuming part is the tear down and clean up before you start going back with new wood!
The picture is miss leading, it's bad, and the skin on this one is vinyl
And patch I'm a carpenter and build for a living, this shouldn't be to difficult, I just got to take my time, which will make it time consuming, like Oldbuck40 says getting it apart and cleaned up is most of the battle
Gonna save this for a later quote! :grin: :grin: :grin:KONA said:I don't see an issue with the hot water dealio, I'm just gonna pull the hot water heater out, to simple not, then it's basically wide open, just stop there last night.
Hows your fancy hot water heater in the moho lolDevilman said:zoom... right over the heads, lol.... :cheesy:
oldbuck40 said:Hows your fancy hot water heater in the moho lolDevilman said:zoom... right over the heads, lol.... :cheesy:
DISTURBED said:Why would you need to heat hot water? crazy.gif
ok you PC MF'RS its a device to turn cold water into hot and also to keep it that way! :grin: :grin: :grin: :grin: :grin:DISTURBED said:Why would you need to heat hot water? crazy.gif
oldbuck40 said:ok you PC MF'RS its a device to turn cold water into hot and also to keep it that way! :grin: :grin: :grin: :grin: :grin:
well in Konas case it could have well been a fire with a pot of water boiling on top of it :cheesy:Devilman said:oldbuck40 said:ok you PC MF'RS its a device to turn cold water into hot and also to keep it that way! :grin: :grin: :grin: :grin: :grin:
which is known in most parts of the world as a water heater. :cheesy: coulda just said that ya know. :grin:
lol well i sure as hell aint never heard it called a cold water heater,,,have you?KONA said:Looks like its gonna take a page to figure out is it a hot water heater or a simply water heater think.gif :laugh:
