Well....I will say that your thrust bearing and impeller play a huge role in the life of your motor. Lol. Last summer my thrust bearing went out.....and subsequently my motor severely overheated. Ever since then I've been having a ton of oil blow by from the valve covers. Three weeks ago myself and veestyle did a compression test and found that cylinders 1, 4, 5, and 8 were all about 80psi....while 2,3,6, and 7 were at 150psi..... (on a BBF 1,4,5 and 8 are on the four corners of the motor)
The general consensus was that the moly rings lost tension and that I should re-ring and call it good. So The past Saturday, Blazeracer, xlr8, and SecondAggie and I pulled the motor and tore it down. I had four cracked pistons. We think it's because of detonation when I overheated the motor last summer.
Today I'm taking the short block to Blaines and having them inspect the block, put new pistons on the rods and re-ring them. Also having them assemble the short block and prep it too.
