Broke Boat
I may this winter when I make new ones. I'm going to make these work for now. It won't be pretty but I got to get on the water and start tuning! Iv played with my boat some this season with the family but haven't got really tune it yet.
jdeaton
What style blade did you use to cut the plates, or did you send them out to a machine shop.  I'm having trouble finding blades that wont gaul up cutting aluminum.
About to walk out the door and drag my winger to EO's so he can check out how i have it setup and pickup an impeller and wear ring! jump.gif
TintMan
A friend cut them out on a bandsaw.
C
CorDog009
Guest
Motor Head said:
no testing for me tomorrow! Turns out transom plates cut for a dominator dont fit a Berk. The clean out cover is taller and needs the opening in the top covered so it can be sealed. There is a good size gap in a few spots on the sides where the dominator is bigger.
Whatcha gonna do with those for the dominator pump?  :smile16: My handhole cover is about in the center of the transom.
jdeaton
OK Thanks, If you talk to him ask him what blade he used, I found as used band saw for 69.00 and I will need to order blades for it.
Motor Head said:
I had them welded up and reworked them to fit. I have a tight pump with an aluminum A impeller now! I'm testing tomorrow.
So you made it over to EO Saturday ?? He told me you talked to him Friday . I went by his shop Friday on the way home and paid on the small block in there .. How did it work ???
Well I'm going to see EO again this morning. When I picked up the impeller and wear ring he told me the side clearance was a little tight. I should have let him turn the impeller a little because it got too tight when after wear ring was installed because after about 10min of cruising out on the lake the side of the impeller stuck to the wear ring. Wear ring is fine, impeller not so much.
Here's a snap of Bobby behind the Crusader.
NOTE: this was not a Ford issue but an impy issue!!!! Lol.
Motor Head said:
Yeah I'm sure he will. Saturday was my first time meeting EO in person. He is a super nice guy!
He is for sure I good guy to work with .. very smart when it come to engines and pumps
