Now you know what to do take it to James.Patchman said:There you go.
Sent from my PG86100 using Tapatalk 2
:smile30:
Patchman said:Mite put some guages on it Cliff! R-134-a is more effecient! Takes less to do the same! Been converting for years and seen pretty much everything! Also keep in mind that too much freon in a system isn't cold either. So you must watch how much you add! :smile30:
Some systems don't function as well with R-134. That's mainly do to the condenser. I've got an 87 f250 that I converted that will give you a headache from the cold. R-12 is not better, nor faster. I will say that if you have a slow leak in an r-12 system, r-134 will leak like a siv do to it being a smaller molecule! When converting the systems, you use 3/4 the charge you would use of r-12. So I would say it does more with less. But keep it r-12 if you want. I used it allot and liked it back in the day! Then the more I converted them, I began liking R-134. Use what you want, a/c is a must! Good luck, and if you have a question, I gladly help where possible! :smile30:72hondo said:Patchman said:Mite put some guages on it Cliff! R-134-a is more effecient! Takes less to do the same! Been converting for years and seen pretty much everything! Also keep in mind that too much freon in a system isn't cold either. So you must watch how much you add! :smile30:
Not doubting you but everyone I talked to said stick with the R12 it gets colder and faster. Plus I'm not going to dump a bunch of money in this truck when I'm getting ready to buy another car. This ones just going to be the tow rig.
Patchman said:Some systems don't function as well with R-134. That's mainly do to the condenser. I've got an 87 f250 that I converted that will give you a headache from the cold. R-12 is not better, nor faster. I will say that if you have a slow leak in an r-12 system, r-134 will leak like a siv do to it being a smaller molecule! When converting the systems, you use 3/4 the charge you would use of r-12. So I would say it does more with less. But keep it r-12 if you want. I used it allot and liked it back in the day! Then the more I converted them, I began liking R-134. Use what you want, a/c is a must! Good luck, and if you have a question, I gladly help where possible! :smile30:72hondo said:Patchman said:Mite put some guages on it Cliff! R-134-a is more effecient! Takes less to do the same! Been converting for years and seen pretty much everything! Also keep in mind that too much freon in a system isn't cold either. So you must watch how much you add! :smile30:
