Shoot at least TWO coats before the first wet sand, if not three. You don't want to cut through the clear anywhere on that thing,
blazeracer said:Just went to the North section and looked it up. I think Beaverfab is his nick?
I'm not sure the planets are going to line up quite that well any time soon! :smile28:ChryslerJet said:Talked to JJ during lunch. Going to pull the gearbox tomorrow night while prepping for the clearcoat. Will be sending him the gearbox to go through it and already got a quote to replace everything if it needs it.
Cliff this one doesn't need me to tear out the floors or split it and I am ready to get on the water. CJ still needs a lot of work get this one out there and then will get the CJ done. If everything goes right might get them both out for RTC.
JJ also gave me some ideas on the Steering on what to do and a quick and easy way to check if its the cables/box or rudder.
Yeah I know keeping my head in the game on the Carlson going to take advantage of the momentum I have right now and get as much done as I can. I am just hoping I won't have to do much to freshen up that motor. It was built right and ran strong last time I ran it.Patchman said:I'm not sure the planets are going to line up quite that well any time soon! :smile28:ChryslerJet said:Talked to JJ during lunch. Going to pull the gearbox tomorrow night while prepping for the clearcoat. Will be sending him the gearbox to go through it and already got a quote to replace everything if it needs it.
blazeracer said:One step at a time, pull the gear box then get that clear on it this weekend.
Prep for clear coat = wash with soap and water, dry completely and start shooting......
ChryslerJet said:blazeracer said:One step at a time, pull the gear box then get that clear on it this weekend.
Not sure I am going to wash it more than the rain has since it will wipe off more of the metal flake. Just wiping it takes it off. May hose it down and let it sun dry then shoot it. Normally I would sand and prep but just won't work here. I am crossing my fingers that everything will stick fine.
KONA said:damn crusader, this dude is an authority, he's got it covered, get it, got it covered :smile16:
KONA said:well i'm sitting in my hole eating pizza, BUT in 15 minutes be hooking up to boat and heading to the river, who's got that covered bawhhahahahahhhaahahahah
Crusader said:KONA said:well i'm sitting in my hole eating pizza, BUT in 15 minutes be hooking up to boat and heading to the river, who's got that covered bawhhahahahahhhaahahahah
Lol....LUCKY!!!!!!!!!!!!!!!
Cliff yeah I know but at the same time it will wash off more of the metalflake. Such a hard decision. I think need to take it to the car wash and do a soft spray soap and light rinse no pressured water. Unless someone has a better ideaCrusader said:ChryslerJet said:blazeracer said:One step at a time, pull the gear box then get that clear on it this weekend.
You need to wash it with soap and water to get any oils or residue from the atmosphere off of it so the clear will stick....
Damn your right still damned if i do and damned if i dontDevilman said:Wish I had some advice for ya, seems like a "damned if you do/damned if you don't" type a situation. One thing to think about is if you do the rinse thing at a carwash, wouldn't it need to be dry for the tow home. I'd think if its wet, crap & road grit gonna get stuck to it & you'll be back where you started.
