Yep, I fully intend to Cliff. I was simply doing a preliminary check to see if was going to be worth investing the time and money into it. Now that I know it is, I will do all the other maintenance that it will need before it hits the water. Including pulling the carbs to clean them, changing fluids, water pump, inspecting and lubricating all the cables, etc. First I will need to redo the floors though so it will be a while before it is ready. I am not sure yet if the the stringers and the transom really need to be replaced but I am not real concerned about that because the deciding factor of the build revolved around the motor. If it hadn't been good then the boat would not have been worth doing.Crusader said:Dave...before taking her out in the water and regardless how much water is going out of the pee hole when on the hose, PLEASE replace your water pump (impeller). I will guarantee you that it is dry rotted.....especially after not being used for 23 years. I replace the impeller on my whacker every other season.
Also, go ahead and change out the lower unit gear lube......
Devilman said:What about the cap.... you planning to pull the cap? :grin:
customtouch said:I was wondering how long it would take before it started!!!! LOL!!! whatever.gif
Devilman said:customtouch said:I was wondering how long it would take before it started!!!! LOL!!! whatever.gif
hahaha, hey you made it to the second page. pretty good for around here. :cheesy: :grin:
customtouch said:Devilman said:customtouch said:I was wondering how long it would take before it started!!!! LOL!!! whatever.gif
Ya, I was impressed!!!! :grin:
I know how to pull the capDevilman said:What about the cap.... you planning to pull the cap? :grin:
ChryslerJet said:David if i had the cash flow I would make you an offer on it.
