EOSpeed said:ALIGN THEM THE BEST YOU CAN AND PUT SOME LASH CAPS AND RUN IT. THE ROCKER WILL HIT THE ROCKER STUD WITH A PUSH ROD THAT WILL CENTER IT. THE LASH CAP WILL MOVE IT UP.
I will mock it up and see where the rocker is to the stud before I order the pushrods..Then I need to make sure the rocker will not pivot too far and hit the stud is what you are saying EO .. If it pivot too much and try to hit the rocker stud then I need the lash caps to help solve that problem by moving everything up the thickness of the lash caps .. ..
Thanks for the heads up on that ..
