Block, get it bored to 4.030... $750
http://www.summitracing.com/newsandevents/media/storydetail/newproductsmedia/Summit-Racing-GM-LS-6-0L-Iron-Block-Now-Available/
Stroker kit #R-KD20135. Comes with a steel crank and rods, forged piston, rings and balanced. $2,000
http://www.flatlanderracing.com/k1-wiseco-02.html
GM Performance LS3/L92 CNC rectagular port heads. With a spring change they flow 354 intake and on the exhaust side. $1,300
http://www.citycratemotors.com/scripts/prodView.asp?idproduct=324220
Rectangular port intake for 4150 carb. $450
http://www.crateenginedepot.com/L76L92-4-Barrel-Intake-Manifold-25534401-P10483C655.aspx
Cam is a Comp Cams hydraulic roller with 255/271 degrees of duration at 0.050, 0.624 lift, and a 115-degree lobe-separation angle.
Hotrod dyno'd this motor with a little bigger stroke at 720hp @ 6,500 and 629 ft lbs @ 4,000
Not bad for a 408 inch small block that can be built with new parts for a little over 5 grand.... Then throw in a power adder!
