ChryslerJet said:
ChryslerJet said:
DISTURBED said:
There should be a couple of tapped, unused holes in the coupler. Thread a couple bolts into them to spread the coupler loose. Good luck!!!!
thanks tim will look at it as soon as the clearcoat dries.
Tim worked great. Now any tricks to taking out the prop shaft?
It slide right out until it came to the rudder, need to remove the rudder to get it out completely. Once it's out should I remove the prop from the shaft? Am I just looking for damage, cracks, breaks, pits and anything else?
Thanks for all the advise guys.
Oh and I should remove the two bolts from the coupler holding it apart while its torn down right or does it matter? Should I remove anything else from the boat besides the rudder, steering and prop shaft.
