Holley to rich at idle
kdub
If you have a power valve you need to see what size you need using a vacuum gauge cuz it sounds like a motor that likes 40 degrees of timing probably has a cam that lacks in the vacuum department, need specs to speculate  :evil:
Widetrack
Kdub, It liked the timing there for balls to the wall running! Vacum ran at idle anywhere from 11.5 to 14 inches! That was depending on the idlemixture screw setting! I backed it down to 36* and put a fresh tune and pulled 13.5 at idle and had damn good vacum throughout RPM range!  WT :smile20:
