sure, i can see mainjets causing issues on a dominator or a 4150 with 1 to 1 linkage but not a 4781. at idle, you're pulling fuel from the idle circuits, then as you mash the gas, the shooters spray in fuel, the motor revs up and creates the signal to the boosters, boosters start pulling fuel thru the mainjets and slobbers it in. that's basic carburetor crackalating :smile13: a dominator with a 3rd circuit will inject fuel into the barrel during part throttle just to keep the signal crisp to the boosters(ie, runnin big ass boosters that normally would have a flat spot in the throttle without the 3rd circuit of fuel). i know 4150's pretty well, its the dominators that took me a longtime to figure out how to tune, they're finicky as hell.
Travis the timing is set at 40* and I have tryed 38* it looses 200 rpm at WOT every 2*droped it will idle a little better with the timing lower! You know love that hit! LOL!
Tom I tried a 3 circuit 1050 and it didn't like it at all it loved the gas pump! :smile14: I had it setup by Lance Patton! The 850 I built, I had to drill the plates and put rescritors in the idle rescritor ports and all of this helped! I am going to turn the screws in some more and see if it helps ! Thanks WT :smile20:
Coby
