SimplyOrange
Gas-Hole said:Like D-man said, it would not be unsafe if it slips while underway, it will just drop the bow, but you WILL need to adjust it while underway, If you set it to roost underway you wont leave the hole with it set like that, IE; Nozzel down to leave, then Nozzel up while underway to Trim/Roost. AND, If I am reading this correctly, the solid wire Morse cable that the controller uses for Engine control is not near strong enough to control the Nozzle.SimplyOrange said:Devilman said:Mine trims up pretty easy, its not that much force on it. Hell my wife does it when she runs the boat. :grin: But you will need something to lock it into place foir sure.
As Gas-Hole mentioned, some of the top notches on my controller are rounded off as well & the lever won't stay put, it'll slip out & drop down a notch or two if I don't hold it in place. I've had it happen, the tail just drops down, but never been a "loss of control" type situation. Loss of roost height control I guess. :cheesy:
If you have the stuff there to put it together & a little time, I don't see what it could hurt. Sounds like it will work to me, other than a possible cable travel issue (too much/not enough). Only way to know is to try it. If you do it just make sure nobody is behind ya when you go up with the diverter, which I would assume most people do that anyway. :wink:
thanks for the info, i have an idea and a backup idea,i think your wife would have a hard time moving my controls right now, but if it does slip, i just got done drawing up a lock on autocad that i could add in 1 day.
that is if i cant put enough drag on the cable combined with the detent springs to overcome the force of it moving.theres got to be a point where i can get enough resistance to be equal to me holding the lever.
i think im about to order the cable and hook it all up, may try it out this weekend. now is perfect time to test stuff because i have the whole river and launch to myself.
depends what series cable, the 60 series has a pull load of 260lbs, the 80 series is more, you are thinking of the light duty 30 series tahat i wouldnt run anyways.
