Devilman said:
Mine trims up pretty easy, its not that much force on it. Hell my wife does it when she runs the boat. :grin: But you will need something to lock it into place foir sure.
As Gas-Hole mentioned, some of the top notches on my controller are rounded off as well & the lever won't stay put, it'll slip out & drop down a notch or two if I don't hold it in place. I've had it happen, the tail just drops down, but never been a "loss of control" type situation. Loss of roost height control I guess. :cheesy:
If you have the stuff there to put it together & a little time, I don't see what it could hurt. Sounds like it will work to me, other than a possible cable travel issue (too much/not enough). Only way to know is to try it. If you do it just make sure nobody is behind ya when you go up with the diverter, which I would assume most people do that anyway. :wink:
thanks for the info, i have an idea and a backup idea,i think your wife would have a hard time moving my controls right now, but if it does slip, i just got done drawing up a lock on autocad that i could add in 1 day.
that is if i cant put enough drag on the cable combined with the detent springs to overcome the force of it moving.theres got to be a point where i can get enough resistance to be equal to me holding the lever.
i think im about to order the cable and hook it all up, may try it out this weekend. now is perfect time to test stuff because i have the whole river and launch to myself.
