Carnivalride said:
Wakemaker said:
Since we're on the subject of cavitation plates, I have a question. Two days after I got my V-Drive I was cruising across the lake at a high rate of speed, at least I thought so, and ripped the left side of my plate almost completely off my boat. When I had the new plates made, I added 2" to the plates because it seemed like the thing to do at the time I guess. The turnbuckles are still in the original place and angle that they were in, but I'm wondering now how this affects my boat. I've done a lot of tweaking to get it to where it feels comfortable and it seems to work good. I was hopping " can't spell porpoising" at first till I added a little more down to the plates, and I smoothed that out really nice. I just wonder if I was to take of an inch or two how that would affect the speed, handling, etc. BTW these are fixed plates.
If longer plates help and they are set up level or "down" in comparison with the back of the hull the boat is riding on them. "If" that is the case shortening the plates will require more "down" to keep the boat riding where it is.
What prop do you have and haw far back is it from the strut? IMO a couple of nickels makes more difference than lowering the plates. Try about 3 nickels in the coupler between the output shaft of the v-drive and propshaft and see what that does for you. Make sure you don't go more than 3/4" away from the strut and less is better on that measurement.
Your next issue is fixed plates it's really hard to make a fixed plate boat run well from off idle to top end.
Good luck
Hey Loren : Adding the nickles that give more tail lift correct ? Pushing the prop back look like it would push the back up more .. or do I have this back ward .. I added one nickle to mine in hope to help from dragging the tail so much ..
Clayton : I would talk to JJ and see what he says about cutting off an inch , I would think I would leave it like you have it now and it is not bouncing on you anymore . unless you start bending the plates or braking parts .
Those turn buckles on back get expensive to buy . I just bought enough to make four complete spares and they were just about a 100.00 per complete rod with the eyelevelers ,clevis pins. base plates and turnbuckles.. So if you start breaking stuff , you need to change back to like it was ..
