Carnivalride said:Congrats Billy those are great numbers for a lake toy. Shouldn't be to finicky on gear either with that broad of powerband. Easy to gear and prop and fun to drive. clap.gif
Brazos River Rat ( Billy ) said:Carnivalride said:Congrats Billy those are great numbers for a lake toy. Shouldn't be to finicky on gear either with that broad of powerband. Easy to gear and prop and fun to drive. clap.gif
Loren - you predicted the HP within 7 HP from when we talked about two months ago .. Very good ..
I will get it in the boat , make a few test run and then make a gear change , maybe if I needs it .. I like to keep the RPM down to 7200 -7400 max ..
When it hit 8200 on the valve train test I think I cracked a couple teeth.Brazos River Rat ( Billy ) said:They was shooting for a RPM range of about 7400 ..So I will try and gear it to around 7000 -7200-7400 Max RPM .. .. I going to let the engine tell me what it likes and gear to that
They did run the engine way up on RPM to make sure ther valve train would handle it .. I am glad I was not there to see that .. or watch the Video of it .. That would have been very scary to watch ..
Now it time for me to get busy ..
Brazos River Rat ( Billy ) said:It's alive .. jump.gif
I need to change my fuel pressure regulator . Mine decided to start leaking today and I had to make a longer braided fuel hose between the fuel inlets , because of BLP metering blocks are a lot thicker than the Holley metering blocks ..
It sounds good . Now just need to finish up all the little things now .. Plus might need to buy a new battery ..
Can't wait to test . maybe in a few more weeks
