So Here is the details on this. Picked it up from our dearly departed techmarine's (Derrick Stover) sweetheart. Dirk had it before Derrick. There is a paper trail that it was sold in 08 and in 2000. Then paperwork prior to that through '72 of the original owner. All paperwork that is older than I am and seems to have faired better than me. I am going to scan all the paperwork and will post it up. Things like rebuilding the carbs on the 426 max wedge and rejetting for general use only costing $28.06 if I recall correctly. Don't think you will get that pricing today. A full rebuild of the motor including two new pistons and a new crankshaft costing just over $500. Today you couldn't get a Master kit for that cost.
So here are some details of it and some shots of it. I think I have decided for now it is going to be clearcoated as is and left that way at least for this season. But I would like everyone's opinions on whether to redo all the paint with the original bright red with heavy metal flake and either mask off or hand repaint all the original hand painted graphics.
I have a 383 Big Block that I built for my barracuda running about 500HP that's going to power this old girl for now.
The hull is in good shape as is the interior all original. There are a few patch spots that I want to redo and the passenger seat was cut off and made to be a removable seat. I want to fiberglass that back in place like it was originally unless anyone thinks I should keep it setup as a removable to preserve the racing history with it. Again give me your thoughts.
The steering cables need to be replaced as the wheel won't turn. The cavitation plate cable may need to be replaced or just the handle. The gas pedal is missing and the cable with it. The Casale drive looks in good shape as does the drive shaft and all the motor mounts. I will have to have made or track down a PTO adapter for it. I will need help with this guys and gals so give me your advice and opinions. Especially from the V-Drive guys and gals. I am going to need to make some front motor plates and a rear motor plate for it.
For Fathers Day I got a GPS unit so I can GPS my speed on both boats.
So as I see it here is the todo list with parts needed.
Clearcoat the entire boat top and bottom
Re-attach passenger seat either as removable or permanent
Re-upholster both seats
Find and install Gas pedal and cable
Repair/replace Cavitation plate cable and lever/pedal
Check out the Casale drive
Find a PTO Adapter
Replace Steering cables
Replace or rebuild Steering Wheel
Replace all drain plugs (all missing)
Rebuild the trailer bunks
Fabricate Front and rear Engine mount plates out of aluminum.
Inspect engine and install
Rewire entire boat.
Buy a 830-850 Holley double pumper
Buy a scoop
Go Play
The list is rather short and very doable just a lot I will be asking for help or guidance on.
Here are a few shots
Find a PTO Adapter
Rewire entire boat.
Buy a scoop
Go Play
