ChryslerJet said:Brake Fluid is designed to break down by absorbing water that will develop in the braking system. It does not have to be changed often but should be flushed out periodically.Crusader said:I've never flushed out a brake system ever. I don't see the need for it unless you are sure it has water in it.
Just like A/C driers/accumulators should be changed out every 5-7 years whether its needed or not. If you do that you can pretty much go a lifetime with an A/C Compressor. Typically what destroys the compressors is moisture which is what the drier/accumulator is for to remove that moisture. Changing the drier/accumulator, vacuuming the system and installing fresh freon typically can extend the life of a working compressor for quite a while.
That was my point dude!
