Jim All I know is it was running pretty wet Saturday and Wayne had the best side view sitting in his boat about 100 ft away and he said I was running really wet and could not see the skag at all .. That was with the plate up about 3/4 inch .. That is too much .. I am not getting the lift I need out of this old prop .. So I don't think raising the plate is going to help me anymore ..
Two year ago I had 850 HP with the 13.6:1 engine and this year I have 950 HP pump gas deal .. the year I had about 1/2 the skag showing was at Tawakoni and that was the E-85 engine and I estimated it about 750 HP .. I never really got to see what the boat would do with the 850 HP engine when it broke the retainers
I will feel better having a new prop under the old boat any way .. Dallas knew pretty much what I needed when I told him what the boat was doing and the changes I made to it .. Let see what she will do in two weeks if I get the prop by then Sept 26 I am hoping to go test ..
I feel better that you are getting the new prop too.
You will know how much it's been used and how.
These prop guys seem to know the props and what we need pretty well and tend to work with us to get where we want to be.
Being up 3/4 inch does seem a bit high, but then it all depends on how you measure.
We can compare our set-ups as they should be similar.
As far as how much up plate there is, I've run the same in mine from when I was told where I would end up.
Mine may be able to be improved on, but it seems to like where it is.
Power wise, I don't think there is much difference from yours and mine.
