stangcorey said:Unfortunately, the Lucas didn't work for me. I let it run for 30min yesterday on the hose and then took it out today on the bayou but same thing. I cant get over 3800rpm, bogging down or hesitating when accelerating, and its not starting without spraying engine starting fluid.
Any chances this couldnt be the carb? I talked to our mechanic out at the airport and he said he'd rebuild it for me for $75 plus whatever cost of the kit. He thinks it could be the accelerator pump...
it was worth the try, but i would say that was not enough time to desolve anything that might have it slugged up, and also i just might be time to rebuild...... has the carb sat for a while? do you have a new fuel filter in it?, does the carb have any fuel or air leaks? have you checked the timing and what does your plugs look like?
