hillbilly68
Last Mohican said:hillbilly68 said:well i took mine out saturday and discovered a fuel pressure issue at wide open throttle, idling and cruising is good as long as i dont stabb it, as soon as i do pressure drops to about 3 lbs, other than that everything seems to run good and handle good,
B O A T break out another thousand................................. crazy.gif
Bigger pump???
yea i have to check a few things first, like if there is any restriction from the tank to the pump, but it may need a bigger pump, or maybe the vents in the cap are not big enough so it might be sucking more fuel than air coming into the tank and trying to collapse the tank
