Gas-Hole said:Fellas, I am going to put my Dragster Scoop back on my Sled, WHERE do I find a tray for Dual Carb's? at this point I am not even sure of the square dimentions of the scoop, just tryin to get a head start.
soldier of fortune said:make one out of a cake pan from walmart
Negative, I still have the single Carb tray, I will take it to my local welding shop and they can pattern it and plasma cut the Carb holes. :smile30:soldier of fortune said:make one out of a cake pan from walmart
See if TxLiberator can cut you one!!Gas-Hole said:Negative, I still have the single Carb tray, I will take it to my local welding shop and they can pattern it and plasma cut the Carb holes. :smile30:soldier of fortune said:make one out of a cake pan from walmart
Local shop 6 miles from house :smile16:ChryslerJet said:See if TxLiberator can cut you one!!Gas-Hole said:Negative, I still have the single Carb tray, I will take it to my local welding shop and they can pattern it and plasma cut the Carb holes. :smile30:soldier of fortune said:make one out of a cake pan from walmart
I could see it workin for sure but ............Nah, do the job once, do it right!soldier of fortune said:i was joking, however i did that one time, on a formula 5000 scoop i had on my centurion picklefork.
my centurion only ran in the mid 70s in the water, but it towed at 80 to the water.Gas-Hole said:I could see it workin for sure but ............Nah, do the job once, do it right!soldier of fortune said:i was joking, however i did that one time, on a formula 5000 scoop i had on my centurion picklefork.
I hear ya, however with my luck it would sink to the bottom of the lake or never make it to the lake! the single carb tray that I have could very well be from Wal-mart, it is WAY to flimsy~!soldier of fortune said:my centurion only ran in the mid 70s in the water, but it towed at 80 to the water.Gas-Hole said:I could see it workin for sure but ............Nah, do the job once, do it right!soldier of fortune said:i was joking, however i did that one time, on a formula 5000 scoop i had on my centurion picklefork.
I have some 3/8" aluminum plate you could make one out of. Hell thinking about it I probably could use that to fab up an intake for the CJ's motor why the hell didn't I think of that sooner?Gas-Hole said:I hear ya, however with my luck it would sink to the bottom of the lake or never make it to the lake! the single carb tray that I have could very well be from Wal-mart, it is WAY to flimsy~!soldier of fortune said:my centurion only ran in the mid 70s in the water, but it towed at 80 to the water.Gas-Hole said:I could see it workin for sure but ............Nah, do the job once, do it right!soldier of fortune said:i was joking, however i did that one time, on a formula 5000 scoop i had on my centurion picklefork.
:smile21:spd500 said:So we will see you on the water next week ? Right ?
Problem is that the newer magnum 360's use a different bolt setup which si what I have. I can't use the intake on the 360 sitting on the trailer cause its the old style. I havent found a used intake for the newer style yet and a new one is $180. Although I already told the wife I would need to spend that until I get the bills caught up with the new job thats not getting spent. I know thats not a lot for some of you but it is to us right now. Yeah I know Boats are an expense but once I have this on the water it wont be as big of one.spd500 said:What exactly is the problem with getting an intake to fit a 360 anyway ? That should be an off the shelf item at any performance shop .
