Brand MSD Ignition
Manufacturer's Part Number 83606
Part Type Distributors
Product Line MSD Pro-Billet Ready-To-Run Marine Distributors
Summit Racing Part Number MSD-83606
UPC 085132836062
Computer-Controlled Compatible No
Trigger Style Magnetic
Advance Type Mechanical
Cap Style Male/HEI
Mechanical Tach Drive No
Slip Collar No
Gear Material Iron
Ignition Box Required No
Distributor Rotor Rotation Clockwise
Housing Material Billet aluminum
Housing Finish Natural
Quantity Sold individually.
Notes UL-approved marine distributor. Roller cam applications may require a different distributor gear.
Marine Use Yes
MSD's new Ready-to-Run marine distributors are the perfect upgrade for boats that are relying on worn-out breaker points or weak ignition systems. These new distributors feature a powerful ignition module built into the billet aluminum housing. That means no extra ignition box is needed! This module produces a stout inductive spark that will improve combustion of the fuel mixture for better drivability. Beneath the durable bolt-down injection-molded cap, a maintenance-free magnetic pickup produces accurate trigger signals, while an oversized shaft is guided by a sealed ball bearing. An easy-to-adjust mechanical advance allows you to custom-tailor a timing curve to match your application. Their Ready-to-Run design makes installation a breeze. Simply drop one in the engine and connect three wires and you're ready-to-run across the lake! All are equipped with flame arrestor holes machined into their CNC-machined aluminum housings, and are supplied with a cap, rotor, gear, and weathertight wiring harness.
