460 buildup
sturat
Why are you pulling your motor? You are running 60+ on the juice with 7 psi of OP.. That thing will last another 5 - 6 seasons i bet?  :police:
hillbilly68
hillbilly68 said:
what kind of compression? i went with flat top pistions in mine and ran 10:5.1 compression, with this cam  http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=990&sb=2  and was very pleased with the results, it had a nasty idle and performed great, i had the procomp alumn heads that had 300cc intake runners $929 off ebay, tunnel ram with QTY 2 little holley 450's on it, last mohican or tahiti rat can tell ya how it ran, they both have rode in it, i built it so i can cruise around the lake or had the power if i wanted to light it up a little, it wasnt the fastest boat on the water but it'd make the chevys groan a little to keep up...lol
I looked at Procomp heads and flat tops too. The Procomp have a 84cc chamber I think. The Ford heads have a 72cc chamber so going with dished piston will net a CR .25 over stock. Looked at that cam, WOW... That's a big one. I don't want a cam too wild on my motor. The spec sheet says you have to machine the heads, use srew srew in studs and guideplates and longer pushrods.
Think we can get Matt to admit he rode in a really fast Ford??
yes they are 84cc chambers, but with the flat tops... plus the procomps have 300cc intake runners so it breathes real good..
and NO you know matt's not going to admit to having a fast ride in a ford, he's skeerd to admit it....lol
Ya, he rode in mine on November 14th and won't admit how fast it is either. Lol.
That's 66.7 on juice there.... ALMOST 70.
neverenuf
hillbilly68 said:
OK, I'm pulling my motor on Sunday and the winter buildup will begin. I read an article a while back on a guy who built a 460 for his boat and had it dyno'd. I wrote down what was used on it and collecting parts has already begun. I want to say the motor dyno'd 536hp at 5,400 or something along that line with 500ft lbs of torque from 3,500 up. It was a very usable power band.
The dyno run was made with logs that the bolts run through (Got em) with no risers.
a Wieand Steath 8021 SCJ aluminum intake (Got it)
A Demon 850 (Got it, but mine's a marine Demon, his wasn't)
Kaase designed Ford racing M-6049-SCJA aluminum heads - http://www.jegs.com/i/Ford+Racing/397/M-6049-SCJA/10002/-1 (They're next)
Topped with 1.73 roller rockers - http://www.jegs.com/i/Comp+Cams/249/1045-16/10002/-1
Comp Cams CL34-247-4 cam and lifters kit - http://www.jegs.com/i/Comp+Cams/249/CL34-247-4/10002/-1
JE forged pistons w/ -28 cc dish weight matched- http://www.jegs.com/i/JE+Pistons/532/170879/10002/-1
Stock rods balanced on both the big end, little end, and over all.
Stock iron crank spin balanced, found a shop in Mesquite that does this.
A high volume/low pressure oil pump was added in place of a stock pump.
Stock 4 bolt block was torque plate bored, line honed on the mains, deck surfaced, and all the other standard stuff.
Everything was held together with high quality ARP bolts and approriate pushrods used as well as a true roller timing chain.
I'm going to drop a marine dizzy on also - http://www.summitracing.com/parts/MAA-YLM567EV/
PHR did a similar motor with P-51 heads, flat tops, bigger cam, automotive headers and a car Demon did 634hp.
Soooo, opinions, observations???
I'm running the same cam as hillbilly68 but with mildly ported D3 heads converted to studs with guideplates, roller rockers and stock size valves with 10.7 compression. It's a good performing cam but it is a little outdated compared to what"s on the market now. It has a nice rumpty rump idle.
Meh.  It was OK I guess.
Just kiddn David. That boat felt pretty damn fast to me.  It was a little spooky though with that motor lifting up like that.  LOL
hillbilly68
[/quote]
lol, yea when i pulled the motor the other day i saw the problem, aaalllllllll that torque and HP i broke the front motor plate, broke it smoooooth in half, i sold the motor, and sold the boat on ebay this past monday, i kinda hated to her go she was part of the family, i had a lot of blood sweat tears & $$$$ in her, but oh well, the new motor and eliminator should blow that one out of the water when it comes to HP and mph................
You gonna have Ford power in the Eliminator?
hillbilly68
yea its a pretty nasty ford thats going in it, it's a 460 bb stroked out to a 501, it was dyno at 740 hp, but i'm going to do a few things to it to get a little more out of it.....................
Well damn... I want to see you get out there with Eric and just piss him off then.. LOL
That wont happen unless he can as good of hull as eric and about 400 to 500 more hp. Dont forget eric will be twin turbo'ed next time out. He is shooting for over 120mph.
hillbilly68
I'd like to come see that. I'll bring the video camera too.
i did it last year when i finished my motor build, in january with 9 inches of snow on the ground,  crazy.gif i had to use 4wheel drive because the boat ramp was a little slick..........and yes it was a little nipplie................
NotImportant-1
Just some food for thought on 460 builds. These builds were put together by Paul Kane (LakesOnly on the 460 forums). He's got a lot of time invested on the dyno and what works and doesn't on the Ford 385 series engine. I just thought it might interest you guys to read a few tried and proven 460 jet boat builds. I have found over the years that his horsepower numbers are conservative on these builds.
Per Paul Kane:
I’ll start with a motor that is essentially just a massaged over 460 that addresses key points of improvement and also increases pep. I like to think of this build as “how the motor was intended to be by the engineers at Ford…before the bean counters and EPA had any influence over the engineering drawings (and compromised them).” Also taken into consideration will be marine application of the engine.
My only concern about these builds is that often the end user is so elated over the results that they subsequently regret not making the engine with a little more power. For this reason, I’ll follow the first build with another that has a few changes that will ad some more horsepower.
Build #1:
· 460 short block with stock rods (ARP bolts) and SRP flat-top pisons. (about 9.3:1…9.6:1 with zero-deck)
· Double-roller timing chain
· Comp Cams Kit with XE262H 218/224@.050” .513”/.520” 110LC. This cam will work with stock D3VE valve train components; snap-on valve stem seals MAY be required for clearance but not likely.
· Intake and exhaust bowl blending of D3VE cylinder heads. Also, exhaust port of D3VE cylinder heads should have the smog bump mostly removed and the exhaust manifold bolt protrusion (bulging from port wall) blended down as much as can be reasonably done so as not to be a flow obstruction.
· Your Edelbrock intake with a Holley 850 #4781 mechanical secondary carburetor.
· Aftermarket dizzy or recurved factory Dura Spark electronic distributor.
· OT headers.
· Zero-deck recommended; .005-.010 acceptable.
The above build should put you in the 360-370Hp range. No heavy substitute pistons! The lightweight SRP flat-top pistons are important to use with stock rods. These lighter flat-top pisons, combined with the impeller-restricting 5200 rpm max, will allow your stock rods to last the life of the engine. This engine should be essentially maintenance free for the life of the engine (just seasonal tune-ups) . The compression ratio will allow you to run pump gas. Special Note: If you are already seeing 5200 rpm with your current (rebuilt) engine, it may be that this motor will not offer you any performance benefit, BUT this must be confirmed by evaluting the components inside your current engine (at teardown).
Build #2:
Same as above but with “D” cup 20cc dish top pistons and D0VE heads
with bowl blends and smog bump removal. (10:1 c/r with 0 Deck).
Roller rockers and guide plates for valve train.
Comp Cams Kit with XM288H 244/254 .580/.585 112 LC.
The above build should put you at around 500HP. 92 octane pump gas required; blending fuel may be required depending on other criteria.
"I chose to not use the D3VE heads in Build #2 because the resulting 9.5:1 c/r will be sub-par for the camshaft utilized. Engine will run okay, but not a perfect overall combination. Sure, you could get dome-top pistons and attend to compression, but then you will have a heavy piston on those stock rods, remember? So then now you need Eagle SIR rods. Etcetera. Not cost effective for the power increase."
In my further review, we could say that Build #2 could indeed use the D3 heads with the valve train mod. HP would come in at 460HP rather than 500HP due to the lower c/r...that's all.
Build #3:
· Stroker rotating assembly with 4.3  crank, 6.800” Chevy H-beam rods and forged pistons, bearings and rings. .030 overbore will be about 521 cubes, .080” will make about 533 cid, but bore only as much as necessary for clean-up (to save future overbores).
· Main stud kit.
· 22cc “D” cup pistons 10.5:1 c/r
· D0VE heads ported as above.
· Solid lifter cam kit about .600 lift and 275* intake/280* exhaust duration @ .050" Roller rockers.
· Holley 850Dp and aluminum single plane intake
This kit will put you at 600HP assuming excellent tune. Occasional valve lash adjustment necessary. 93 octane (Possible blend fuel) minimum
(This is Basiclly the build I started with for several reasons. Horsepower estimate was low proven out by the RPM  against an aggressor B impeller. 5950 Rpm=630 hp according to the Jacobs pump calculater. Followed by a larger custom grind cam after first build. 6150 Rpm=689 hp according to the Jacobs pump calculater. Per ESA)
Build #4:
Same as above but with TFS aluminum heads. 650HP minimum, with the potential for way, way more with cam, compression and carb changes (800HP possible).
Build #5
· Stroker rotating assembly with 4.3 crank, 6.800” Chevy H-beam rods and forged flat-top pistons, bearings and rings. .030 overbore will be about 521 cubes, .080” will make about 533, but bore only as much as necessary for clean-up (to save future overbores). 10.8:1
· Main stud kit.
· D3VE heads as in Build #1 plus valve train mod.
· Cam kit with Comp Cams XM298H 254/264@.050, .585/.588, 112LC
· Your Edelbrock intake with a Holley 850 #4781 mechanical secondary carburetor or single plane manifold w/Holley 950HP
Neighborhood of 550HP, a little less sith the smaller carb abd a little more with the bigger carb. Hydraulic lifters andmaintenance free. Pump gas premium.
The beauty of Build #5 is that if you choose to upgrade a season or two later, the shortblock and motor stay in the boat. Either do some max effort porting on the D3VE's or swap to TFS aluminum heads. The aluminum heads, with more cam and carb, could generate well over 700HP on Race Gas 110 octane or better.
Just some food for thought. Take it for what it cost ya.
ESA
Man, my wife needs to get back home!! I didn't get to do squat to the boat yesterday, but I sold and delivered a few appliances putting another K of cheddar in the bank.
Good info ESA. All great food for thought.
I'm probably close to build 2 in cam specs only. Other than that, forged pistons and FMPP aluminum SCJ heads and I'll (hopefully) be rocking an AA impeller at 5,000 to 5,200 with no juice, which stock crank and rods can handle all day long.
