veestyle said:12JC with jetovator. you really want a panther pump though.
KONA said:really can't see enough to be 100% for sure, but I believe it's a JE with place diverter
KONA said:only difference is the F bowl came with a jetovator, and that's not a F bowl
DISTURBED said:I would guess that your pump thrust bearing failed. This allowed your impeller to eat the wear ring and subsequently, wiped out your main bearing in the engine.
Just a guess. And just $.02.
I hope it's not all that! Good luck.
blazeracer said:Seen it before where the bearing in the pump goes out and pushes the crank on the motor forward trashing the thrust bearing in the motor. Looks like the wear ring is fused to the impeller? Definitely the kind of pump bearing failure that destroys a motor. Bet it runs hot too.
100% 12-JE pump. I have one with all the good stuff in it. It works well. Is it on a Taylor SS?
PLANEJIM said:The story gets worse-pulled the motor, as I was pulling the flex plate off the crank I noticed patches of JB Weld on both sides of the engine on block. The patches of JB Weld were loose and they popped off like plaster with a slight push of screwdriver. Surprise, Surprise-this engine block has been patched and put back together-WHAT A JOKE-this was a poor buy on my part and definitely needs a engine now.
I am lost for words, frustrated, aggravated and just was starting to enjoy the JetBoat Scene-
sometimes cracked blocks can be repaired. dont be discouraged. worst case find a good block and swap everything over.PLANEJIM said:thanks Patch-I hope I have the pocketbook!!!!!!!!!!!
