Scooters-Revenge
Ok guys~ I have a starter issue that some of you might have ran into before.
The situation: I upgraded my motor. jump.gif
Thus I replaced my motor and reused the top mounted starter & bell housing rear mount- etc.
This means I have a new block and flywheel.
I started this same motor set up on a run stand with a typical block mount starter and it started great.
However now using the top mount starter & bell housing it sounds like it needs to be shimmed like something bad…
I know it was tight fitting in the bell housing so I wouldn’t see how. crazy.gif
let me know if you know..
& I appreciate the help~!
