Steel Braided fuel lines
I figured out a little trick that might help some of you when building steel braided lines.  The smaller the line the harder it is to slip in to the anodized fittings.  I was building lines from fuel regulator to the carbs.  It was #6 lines.  I was making up new vocabulary words cause the line would not slip on.  Once you cut the line with tape around where you cut with a cut-off wheel it still has a little lip.  This is what helped me: Talk a hose clamp and squeeze the very end with it and it will draw the steel in, then slip off the tape.  You might need to take a very small flat head screwdriver to clean any frayed strains in. Once in twist a little to get it started then take a dead blow hammer and drive it on in.  After I did the hose clamp squeeze I was rock'n.  Hope this helps someone.
demonmaestro said:
I didn't have no issues running my #6 braided line.. I just cut it and slipped it in  :tongue:
Maybe you are a little looser there Demonseed! think.gif :evil:
