emersonclay
Anyone know of a jet boat mechanic in the san antonio area.
and or does anyone know what happened to Dwyane?
COONASS said:sale your boat and get a go cart ..................it doesn't have a bat. :smile23: :smile23: your fuel pump has nothing to do with the voltage going to the starter...........unless you have one bad A$$ fuel pump like at the gas station :smile20: I guess'n you are right you need to find a mech. :smile23:emersonclay said:Bats are good had them both tested AND charged at an autozone. Bat connections look/seem good. When i turn the key to the on position, the fuel pump fires up... so it seeeems like its getting juice.. at a loss here.... bat. connections are good right .................the wire that goes from the bat. to starter and the black wire that is grounded to the motor? If they are good then it will help to see if your bat's are give'n good voltage when crank'n............turn key look at volt meter gauge and see if it drops below 9V , if it does then your starter may not be the prob. :smile12: might just be some shorted cells in the bat. ...................usually happens to bats when you leave something on along time to drain them down all the way................if you need help just go to autozone they can check out everything starter , alt , and bats :smile15: and by the way there is only 2 bolts that hold the starter on the block :huh:
COONASS said:MICH said:coonass your funny???????
funny how ........... :smile23:
