calereeves
Are there reverse rotation pumps available? Looking for something that could be run as a matched pair of counter rotating pumps... Just a curiosity thing for now.
Duanehydro said:http://www.youtube.com/watch?v=KUX347RsFGg
closeest I could come to answering your question.
I don't drink the koolaid or the river waterDrumZilla said:CJ ...have you been drinking .... crazy.gif
Correct, the Water rotating out of the Nozzle has no effect on the Boat as there is no Counter Rotation effect that is caused by the Props rotation in the Water.Crusader said:There's still rotational flow coming out of a pump. Unless there's vanes in the nozzle that stops the flow, the water will still be rotating....just like with a prop. The only difference in a jet is that you don't have the rotational forces fighting each other because of the nozzle, like you would do with the non directed flow of two rotating props
SimplyOrange said:at one point I was thinking of putting twin 5.3ls1 or twin skyline inline 6 engines in a hull I have.
http://www.berkeleyjet.com/c-665-intake-assembly.aspx
calereeves said:SimplyOrange said:at one point I was thinking of putting twin 5.3ls1 or twin skyline inline 6 engines in a hull I have.
Twin aluminum 5.3s is what I was envisioning when I started wondering about the reversed pumps.
But then you would have to have one of the 5.3's run in reverse rotation for that to work. Much less expensive to just use two standard rotation motors and pumps.calereeves said:SimplyOrange said:at one point I was thinking of putting twin 5.3ls1 or twin skyline inline 6 engines in a hull I have.
